Hi colleagues,
I get the following messages when trying to build a snap for arm64. Any help is aprecciated.
boschrexroth@app-builder-amd64:~$ sudo apt update
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://security.ubuntu.com/ubuntu focal-security InRelease
Err:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
444 [IP: 10.0.2.2 3128]
Err:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:5 http://ports.ubuntu.com focal InRelease
Hit:6 http://ports.ubuntu.com focal-updates InRelease
Reading package lists... Done
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease 444 [IP: 10.0.2.2 3128]
E: The repository 'http://archive.ubuntu.com/ubuntu focal-updates InRelease' is no longer signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease 444 [IP: 10.0.2.2 3128]
E: The repository 'http://archive.ubuntu.com/ubuntu focal-backports InRelease' is not signed.
*EXPERIMENTAL* --target-arch for core20 enabled.
Setting target machine to 'arm64'
Err:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Err:3 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:4 http://ports.ubuntu.com focal InRelease
Get:5 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:7 http://security.ubuntu.com/ubuntu focal-security/main amd64 c-n-f Metadata [10.1 kB]
Get:8 http://security.ubuntu.com/ubuntu focal-security/universe amd64 c-n-f Metadata [14.4 kB]
Failed to update the package cache: Some files could not be downloaded:
failed to run apt update
Check that the sources on your host are configured correctly.
The terminal process "/usr/bin/bash '-c', 'snapcraft --destructive-mode --enable-experimental-target-arch --target-arch=arm64'" terminated with exit code: 2.
