Access on configuration from custom snap
I will build a custom snap. It is the telegraf agent with an developed plugin for the datalayer SSE.
in the snapcraft.yml there will be something like this
grade: stable
confinement: strict
apps:
  ctrlx-telegraf:
    command: telegraf --config <PATH-TO-CONFIG>/config.conf
    daemon: simple
    restart-condition: always
    plugs: [network-bind]
The file config.conf is in toml syntax eg.:
[[outputs.influxdb_v2]]
  urls = ["https://ingest.example.de"]
  token = "xxxxx"
  organization = "ctrlx-vlab"
  bucket = "ctrlx"
[[inputs.ctrlxcore]]
  url = "https://192.168.1.1"
  username = "boschrexroth"
  password = "boschrexroth"
  node = "scheduler/tasks/ctrlXAutomation/info/counter"
  publishintervalms = "100"
  insecure_skip_verify = true
Questions:
1. Is it possible that this config file is part of the configuration which can be saved,downloaded, imported by the user via the webui?
2. Which path shall be specified in the snapcraft yaml?
Sorry for the delay.
To store data into the configurations manageable via the ctrlX CORE web interface you simple connect to the solution manager with a plug in your snapcraft.yaml:
plugs:
  active-solution:
    interface: content
    content: solutions
    target: $SNAP_COMMON/solutions
An them simply store your file in the active configuration:
/var/snap/rexroth-solutions/common/solutions/activeConfiguration/MyUserApp
