rexroth cml40.2-sp-330-na-nnnn-nw
I've just started working with PLC rexroth cml40.2-sp-330-na-nnnn-nw and i would like to know can i use CODESYS with that plc or which programm i should install?
Best reply by CodeWasi
Hello Tirke,
the control you mention is a very early version - at least 15years old - tend to 20 years. I guess these had been engineered with codesys (early version ) which had been included in a early Indraworks.
Do you need to work with that part for sure... periphery had been connected with Sercos2 for instance.
Before guiding you to the Service colleague or our MLC/Indraworks support forum - please consider to check the necessity to work with that old device - It will be painful .... starting to arrange the tools like Indraworks ... that early version may require former Windows versions... can not remember there titles anymore.
If you want to check out the forum news of the current MLC Motioncontroller solutions:
https://connect.bosch.com/communities/service/html/communityoverview?communityUuid=e41ec603-cb11-4df1-a286-edc2fd551fb9#fullpageWidgetId=Wd1a355208915_423a_9e68_d59308817c00&show=forums
or
https://store.boschrexroth.com/Automation/Automationssteuerung?cclcl=de_DE
Bye
If you are starting with PLC-Programming and you can consider to start with a virtual ctrlX and run the code without HW-IO virtually. If so - you will find lots of usefulls intro-videos...in the area of "how-Tos-  "
