Problems to connect with HCS01
Hallo,
I'm new on this forum
I,ve no experience with Indraworks / Indradrive CS, so hopefully somebody can help me.
I have a Servomotor MSK040B.... and Indradrive CS out of a working occasion-machine.
I want to gain experience for re-using this in our factory.
I connect the servormotor and Indradrive CS and it is starting up well.
I download software Indraworks DS, but ...there is no connection with the Indradrive CS.
May be the problem is, the Indradrive was in a netwerk of many Indradrive's in the occasion-machine.
So, what can I do to make connection with my single Indradrive cs ? Reset the Indradrive ?
What can I do to reset the Indradrive CS ?
Thanks a lot for helping me
Kind REgards
Best reply by Open
Hi wimborsboom,
In the Indradrive CS panel navigate to "Protocol Comm." > change to "Eth. IP" and restart the Indradrive CS.
Then in Indradrive CS panel navigate to "Ethernet" set your IP address for the ethernet ports.
connect your cable from engineering PC to the Ethernet port of the Indradrive.
IndraWorks Ds search the IP address of the Indradrive CS.
you should be able to see the IndradriveCS in the IP address search engine.
Warmest regards,
