GoHawks and Dias ,
for the time being the ICS Input element muting is not available for IO on the SAFEX-C.1x.
A short term solution or workaround has to be addressed in the application talks.
For the later a clear specification of the expected behavior has to be provided, e.g. to generate a work-around:
- What alarms shall be muted?
- Is it just a bypass that shall mute the activation of the light curtain?
- If it is a bypass, are there any other limitations to be added? Min/Max time, etc.
- What inputs and outputs shall the workaround block have?
- What input/output behavior is expected as truth table and in time dimension?
Dias : Any proposals for a workaround?
Best regards
Your ctrlX SAFETY team
