With the ctrlX PLC 1.18 version we can import a PLC Open xml file without problems. When we import the same file with the ctrlX PLC 1.20 version we get an error: Object reference not set to an instance of an object. If we remove variables from type POINTER_TO_XXXX in the variable declaration then the PLC Open XML import goes well. It seems that in the ctrlX PLC 1.20 something has been changed regarding PLC Open XML import.
Import PLC Open xml file gives an error: Object reference not set to an instance of an object
Best reply by HmiGuide
Please read this article, which describes a better way to convert code.
