.EXP file into ctrlX PLC
I have a wago program exported as codesys .EXP file. Is it possible to import this program into ctrlx PLC?
Best reply by bostroemc
As described in this post in external forum, CODESYS v35 (32-bit) does support a v23-to-v35 conversion tool.ย  (See answer from aliazzz.)ย  If you have the original .pro file, maybe this would be a potential workaround.
Since ctrlX PLC Engineering is based on the 64-bit version of CODESYS, direct support for .pro conversion (or for importing the associated .exp file) seems unlikely.
The conversion tool is described here:ย https://store.codesys.com/de/codesys-v2-3-converter.html
Note that 64-bit support is explicitly excluded.
