EthernetIP Adapter - node address to read the tags - ctrlX PLC Fieldbus communication
Hi there,
Learning from this EthernetIP demo : ctrlX CORE – CODESYS Fieldbus Communication – Ethernet/IP
I would like to read the ENIP tags from a third-party ethernetIO scanner.
What is the node address that should be used to read the EthernetIP tags ?
I tried with "ns=1;s=[ctrlX_CORE]output_data[0]", but with no success.
Thanks in advance
Is this still an issue? Or how was it solved?
Could you more  describe how you want to access this data? As your control seems to be EtherNet IP Adapter you will need to configure it as device in your Scanner control to have cyclic access.
Lie MauMX2 said if you add them to your symbol configuration it would also be possible to access them via CODESYS V3 or OPC UA (if server app is installed).
