08/25/2025
How-to | SDK
Build a snap with HAILO 8 integration
Disclaimer
This guide is not intended to be a substitution of the official documentation which is provided by the partner.
Requirements
  • A ctrlX CORE equipped with an HAILO 8 chip
  • Hailo Packets and software available here
  • Being used to build with snapcraft
  • Build natively on arm64 if using the x3
  • core22
Scaffolding
The folder structure is the following:
Folders in the hailo project
Permissions, the right plugs
In order to be able to interact with the chips we need to insert the right plugs and select them inside the app we would like to use to command the chips.
plugs:
  hailo-0:
    interface: custom-device
    custom-device: ctrlx-hailo-0
  hailo-1:
    custom-device: ctrlx-hailo-1
apps:
  myfancyapp:
    command: bin/mywrapper.wrapper
    daemon: simple
    plugs:
      - hailo-0
      - hailo-1
Include the packages in the snap
We need to first download the packages that we need depending by our firmware (linked to ctrlX OS version) and python runtime version (linked to core version). To import the Debian package we just need to link the Debian packages locally. To link the libraries the code is usually more complex and it is better to execute the code after another "python" libraries block to have the runtime automatically imported by the Snapcraft technology.
  mylibs:
    plugin: nil
    source: ./customPackages
    build-packages:
      - python3-dev
      - python3-wheel
      - build-essential
      - python3-setuptools
    after:
      - pythonlibs
    override-build: |
        echo $SNAPCRAFT_ARCH_TRIPLET
        case "$SNAPCRAFT_ARCH_TRIPLET" in
          *aarch64*)
              WHEEL_FILE="hailort-4.15.0-cp310-cp310-linux_aarch64.whl" ;;
          *x86_64*)
              WHEEL_FILE="hailort-4.15.0-cp310-cp310-linux_x86_64.whl" ;;
              echo "Unsupported architecture!"
              exit 1 ;;
        esac
        ls
        echo "The dependencies are installed in the flask part to avoid conflicts"
        python3 -m pip install --no-deps --no-cache-dir -I $WHEEL_FILE -t $CRAFT_PART_INSTALL/lib/python3.10/site-packages/
        craftctl default
  mydeb:
      plugin: dump
      source:
        - on arm64: ./customPackages/hailort_4.15.0_arm64.deb
        - on amd64: ./customPackages/hailort_4.15.0_amd64.deb
      source-type: deb
A complete snapcraft example
version: 0.1.8
summary: Python AI starter kit
description: 'Simple Webbased Editor'
base: core22
confinement: strict
grade: stable
architectures:
  - build-on: amd64
  - build-on: arm64
apps:
  jupyter:
    command: bin/jupyter.wrapper
    daemon: simple
    plugs:
      - network-bind
      - active-solution
      - network-status
      - hardware-observe
      - network-observe
      - serial-port
      - hailo-0
      - hailo-1
      - datalayer
    environment:
       "LD_LIBRARY_PATH": "$LD_LIBRARY_PATH:$SNAP/usr/include:$LD_LIBRARY_PATH:$SNAP/usr/lib/$SNAPCRAFT_ARCH_TRIPLET:$LD_LIBRARY_PATH:$SNAP/usr/lib/$SNAPCRAFT_ARCH_TRIPLET/lapack:$SNAP/usr/lib/$SNAPCRAFT_ARCH_TRIPLET/blas:$SNAP/usr/lib/python3/dist-packages"
       "PATH": "$PATH:$SNAP/usr/lib/"
  desktop-launch:
    command: bin/desktop-launch
    plugs:
      - desktop
parts:
  flask:
    plugin: python
    build-environment:
      - PYTHONPATH: "$SNAPCRAFT_PART_INSTALL/usr/lib/python3/dist-packages"
    python-packages:
      - flask
      - jupyterlab==4.0.2
      - numpy==1.23.3 #for hailo
      - opencv-python
      - pillow
      - zenlog
      - matplotlib
      - ctrlx_fbs
      - ctrlx_datalayer
      - argcomplete #for hailo
      - contextlib2 #for hailo
      - future #for hailo
      - netaddr #for hailo
      - netifaces #for hailo
      - verboselogs #for hailo
    source: .
    stage-packages:
      - wget
      - git
      - zip
      - libssl-dev
      - libcurl4-openssl-dev
      - libcurl-dev
      - pkg-config
      - build-essential
      - libusb-1.0-0-dev
      - unzip
      - ffmpeg
      - python3-wheel
    build-packages:
      - python3-dev
      - python3-wheel
      - build-essential
  mylib:
    plugin: nil
    build-packages:
      - python3-dev
      - python3-wheel
      - build-essential
    after:
      - flask
    override-build: |
          *aarch64*)
          *x86_64*)
              exit 1 ;;
        esac
        ls
        craftctl default
  mydeb:
      plugin: dump
      source:
      source-type: deb
  shscripts:
    source: ./shscripts/
    plugin: dump
    organize:
      '*': bin/
  configs:
    source: ./configs
    plugin: dump
    organize:
      'package-assets/*': package-assets/${SNAPCRAFT_PROJECT_NAME}/
plugs:
  datalayer:
    interface: content
    content: datalayer
    target: $SNAP_DATA/.datalayer
  active-solution:
    interface: content
    content: solutions
    target: $SNAP_COMMON/solutions
  hailo-0:
  hailo-1:
slots:
  package-assets:
    interface: content
    content: package-assets
    source:
      read:
        - $SNAP/package-assets/${SNAPCRAFT_PROJECT_NAME}
  package-run:
    interface: content
    content: package-run
    source:
      write:
        - $SNAP_DATA/package-run/${SNAPCRAFT_PROJECT_NAME}
hooks:
  connect-plug-active-solution:
    plugs: [active-solution]
Sonstiges
