03/14/2024
SICK | App | Safety
SICK - Safe Portal
Reliable and productive solution for human-material differentiation
The Safe Portal solution is used for efficient access monitoring at material transfer stations. The standard variant is featuring two vertically aligned safety laser scanners. It enables seamless and reliable protection for applications up to PL d through intelligent field evaluation. Unlike alternatives for human-material differentiation, the protective devices stay active, ensuring uninterrupted personal safety in any situation. At the same time, objects with predefined contours on a transporting system such as mobile robots, skillets or skid systems can safely pass through the portal. You will benefit from very flexible production processes at high productivity.
Your Benefits
  • High plant availability using reliable safety laser scanners to protect your application.
  • Adaptive production processes with a flexible manufacturing where different transport systems like mobile robots, skillets or other objects can pass through the portal.
  • Seamless protection thanks to active protective devices in any situation: no safety gaps even during material passage
  • Take advantage of SICK's expertise for an efficient implementation of the Safe Portal solution in your ctrlX automation system.
Safety Zone
Safety zone of a machine
Contact us now for your individual Safe Portal solution! From consulting to commissioning support, SICK provides comprehensive assistance in conception, engineering, validation, and system acceptance.
  • ctrlX SAFETY controller
Curious?
From factory automation to logistics automation and process automation, SICK’s sensor solutions are keeping industry moving. As a technology and market leader, SICK provides sensor intelligence and application solutions that create the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents, and preventing damage to the environment.
Categories
Engineering
Platform
Windows
Vendor
Partner Apps
