I'm fairly new to ctrlX platform, but after reading the doucments from the hardware and ctrlX platform/apps, I was able to set everything up and commissioning all axes seperate from each other without any issues.
The next step is using kinematics, but I get this error 0C5604A1 in the web interface, I had read that it has to be with a incorrect configuration of the MCS set. Only I've not set any working areas, as far I'm aware, for commisioning it's not necessary.
I'm working with the following hardware:
ctrlX Core X3
ctrlX Drives, XCD and XMD
All communication is over EtherCAT. Current motion app version in use is v2.6.10, and I've all licences need to commisioning a delta robot.
Am I missing a configuration part or anything else?
Thanks in advance.
