Hello Community,
I have a PLC BOOL variable, when become true i want to trigger an inject node 1 time, how can it be done?
Warmest regards,
Hello Community,
Warmest regards,
I guess you are talking about an inject node in Node-RED. I would simply subscribe to the Boolean value and check in a function if its true and pass a message to the following nodes for that case. So your function is the trigger and no inject node is needed.
