04/20/2023
Bosch Rexroth | Solution Sets | Milling
Solution Sets for Milling Manufacturing
ctrlX AUTOMATION offers the most open & compact Automation Solution for Milling Manufacturing
Find more information about Milling Manufacturing.
Please select your preferred solution set and customize your individual configuration with the ctrlX Configurator.
  • 3 Axis Milling Machine
  • Milling Machining Center
  • 5 Axis Milling Machine Gantry Type
Milling is a machining production process in which the material is shaped by means of geometrically defined cutting edges. In 2.5D milling, the workpiece is machined in 3 dimensions X, Y and Z.
[gallery images="1-3"]
Milling Machine | 3 Axis | CTRLX508888
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX508888"]
A machining center is a machine tool suitable for complete machining, i.e. it includes the functions of a milling, turning and drilling machine. It also has an automatic tool change.
[gallery images="4-8"]
Milling Machining Center | CTRLX670753
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX670753"]
In 5-axis milling, the milling tool is moved along five different axes simultaneously by means of the MTX control. This enables the machining of very complex parts, such as free-formed surfaces.
[gallery images="9-12"]
Milling Machine | Gantry Type | 5 Axis | CTRLX656901
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX656901"]
Solution Sets
HMI
Motors
Production Machines
