01/29/2024
Bosch Rexroth | Solution Sets | Dispensing
Solution Sets for Dispensing applications
ctrlX AUTOMATION provides the most open & compact Automation Solution for Dispensing
The Automation Solution for Dispensing is ideal for various dispensing applications, e.g. sticking or sealing. It can be used in a range of areas from the automotive and packaging industry to battery and semiconductor production. The integration of various compatible dispensing heads allows you to carry out dispensing processes including spreading, filling or spraying.
Find more information about the Smart Function Kit for Dispensing tasks.
Please select your preferred solution set and customize your individual configuration with the ctrlX Configurator.
  • 2D Axis Dispensing Solution
  • 3D Axis Dispensing Solution
  • High-end CNC Dispensing Solution
2 Axis - X, Y solution with dispensing head.
[gallery images="1-4"]
Dispensing Solution | 2D Axis  | CTRLX975169
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX975169"]
3 Axis - X, Y, Z solution with dispensing head.
[gallery images="5-7"]
Dispensing Solution | 3D Axis | CTRLX851404
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX851404"]
3 Axis - X-Gantry, Y, Z high-end solution with dispensing head.
[gallery images="8-11"]
Dispensing Solution | High-end CNC | CTRLX633114
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX633114"]
Solution Sets
Packaging
Semicon & Electronics
