04/20/2023
Bosch Rexroth | Solution Sets | Building Automation
Solution Sets for Building Automation applications
ctrlX AUTOMATION offers the most open & compact Automation Solution for Building applications
ctrlX AUTOMATION integrates the entire building technology, media control, industrial communication and apps in one solution. The possible applications for cross-trade building automation in industry range from simple light control using motion detectors to complex controls such as the co-ordination of sun protection and air conditioning.
Select your preferred solution set and customize your individual configuration with the ctrlX Configurator.
  • Lighting Solution
  • Shading Solution
  • Heating, Ventilation and Air Conditioning Solution
  • Data Collection Solution
  • Control Shopfloor Media Solution
Lighting Solution
Optimized illumination, save energy and light up scenes. Switch on, switch off and dim light in correlation with presence, brightness or scenes. Typical used in factories, offices, retail, warehouses, etc.
[gallery images="1-3"]
Lighting Solution | CTRLX672831
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX672831"]
Shading Solution
Save energy, more coziness and well-being. Shading / blinds dependent on sun light, in- and outside temperature, wind and scenes.
[gallery images="4-6"]
Shading Solution | CTRLX356681
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX356681"]
Save energy, more coziness, less breeze. Automatic regulation of temperature, humidity, CO2 and air quality.
[gallery images="7-10"]
HVAC Solution | CTRLX663186
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX663186"]
Record signals and process them. Track all control-signals and conditions in the building for visualization.
[gallery images="11-13"]
Data Collection Solution | CTRLX154874
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX154874"]
[gallery images="14-16"]
Control Shopfloor Media Solution | CTRLX318307
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX318307"]
Solution Sets
IO
Building Automation
