01/29/2024
Bosch Rexroth | Solution Sets | Beam Cutting
Solution Sets for Beam Cutting applications
ctrlX AUTOMATION offers the most open & compact Automation Solution for Beam Cutting
Find more information about Beam Cutting.
Please select your preferred solution set and customize your individual configuration with the ctrlX Configurator.
  • 3 Axis 2D Beam Cutting solution
  • 3 Axis 2D Beam Cutting solution High Speed
  • 5 Axis 2.5D Beam Cutting solution
3 Axis - X, Y, Z solution with gantry.
[gallery images="1-4"]
3 Axis 2D Beam Cutting solution | CTRLX645608
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX645608"]
Project Example for Beam Cutting Application
[link-button type="secondary" text="Open project" target="_blank" href="https://community.boschrexroth.com/ctrlx-automation-how-tos-qmglrz33/post/template-for-mtx-beam-cutting-u4MWPHk6cnTCKek"]
3 Axis - X, Y, Z solution with high dynamic linear motors.
[gallery images="5-8"]
3 Axis 2D Beam Cutting solution | High Speed | CTRLX185473
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX185473"]
2.5D machines are used for cutting tubes and flat material with bevel head.
[gallery images="9-13"]
5 Axis 2.5D Beam Cutting solution | CTRLX961709
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX961709"]
Solution Sets
Motion
Production Machines
