01/29/2024
Bosch Rexroth | Solution Sets | Assembly
Solution Sets for Assembly applications
ctrlX AUTOMATION provides the most future proof Automation Solution for your Assembly Project.
Find more information about Assembly Lines.
Select your preferred solution set and customize your individual configuration with the ctrlX Configurator.
  • Assembly Line
  • Assembly Module
  • Assembly Subsystem
Assembly Line
Application example of compact assembly line with integrated handling, transport and testing process.
  • PLC with Motion Control.
  • Web based HMI solution.
  • Multi axis drive system.
  • Fast & compact Safety solution incl. SafeMotion.
[gallery images="1-3"]
Assembly Line | CTRLX987014
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX987014"]
Assembly Module
Application example of assembly module for linear transport.
  • Compact 3 axis drive solution with integrated PLC control.
  • Possible Web based HMI solution.
  • Modular expandable.
[gallery images="4-6"]
Assembly Module | CTRLX619434
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX619434"]
Assembly Subsystem
Intelligent mechatronic subsystem with the possibility to integrate your process function, like joining, pressing, tightening, feeding…
  • Compact solution in one device – control & drive.
  • Integrate your own process app.
  • Optional SafeMotion.
[gallery images="7-9"]
Assembly Subsystem | CTRLX905714
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX905714"]
Solution Sets
HMI
Motion
Assembly Lines
