03/19/2025
Bosch Rexroth | Solution Sets | Coil lines
Solution Set for Coil lines
ctrlX AUTOMATION offers the most powerful Automation Kit for Coil lines
The Kit for Coil lines from Bosch Rexroth based on ctrlX AUTOMATION simplifies and accelerates the development and commissioning of Roll feed and Flying Saw Applications.
Benefits of powerful automation for Coil lines 
  • Highest future proof system
    • High sustainability due to extreme long availability of all components
    • „CRA-ready“ through integrated mechanisms
    • Machine safety SIL 3
  • Better Time to market
    • Preconfigured system solution including HMI template
    • Webbased Engineering and HMI
  • Open and easy to use
    • Simple synchronous axes and axis coupling
    • Open and flexibel to create your own IP
  • 30 years of experience
    • Third generation since 1989
Bosch Rexroth offers a modular software and hardware solution set for easy integration in industrial coil line applications. The solution set relies on open standards and interfaces provide high degree of freedom. The big benefit for the customer is less development work and shorter time to market. 
[gallery]
Configuration example in the field of coil line. Customize your individual configuration with the ctrlX Configurator.
Coil line solution | CTRLX904802
[link-button type="secondary" text="Open configuration" target="_blank" href="https://www.boschrexroth.com/ctrlx-configurator/#/solution/load/CTRLX904802"]
2
Solution Sets
Production Machines
Manufacturing
