12/01/2025
How-to | IoT | SMB
Mount SMB network folder
Mount network share (SMB)
This how-to describes the integration of a remote Windows file system into a ctrlX CORE environment using a Common Internet File System (CIFS) mount, which is based on the Server Message Block (SMB) protocol. This integration enables the ctrlX CORE to directly read and/or write data stored on a Windows host.
Requirements
  • ctrlX CORE and active connection to a windows system
Step-by-Step Guide
Go to settings (1) on ctrlX CORE and then to menu storage (2)
Select menu to mount windows folder
Add network folder
Mount network share
Select SMB
Select SMB
Make following adjustments
  • Server -> IP- address of Windows- host
  • Share -> Folder name on Windows you want to share
  • Username -> Window user name
  • Password -> Windows password from your windows user
Adjustments for network folder
After you clicked on mount, the networkfolder will be visible on ctrlX CORE
View folder content
If you click on the small folder icon you will see the content of the Windows folder on ctrlX CORE
Content of network folder
Windows adjustments
Adjustment of Windows folder you want to mount in ctrlX CORE.
Select your folder, right click, select Properties
Right click on folder and select properties
Go to menu "Sharing" then button "Share"
Select menu Sharing and click on button Share
Select user
Select user
Production Machines
Assembly Lines
Sonstiges
