07/31/2026
How-to | LabJack | ctrlX CORE | DAQ
How to run LabJack LJM Application on ctrlX CORE for oversampling data
Overview
LabJack devices are accessed using the native LabJack LJM library. Python applications use the labjack-ljm Python wrapper to communicate with this library.
On ctrlX CORE, the native library, Python application and required configuration files must be packaged inside a snap.
Here is the simpler way to install LabJack LJM library in ctrlX OS to communicate with the LabJack T7 device.
Hardware
  • ctrlX CORE X3/X5/X7
  • LabJack T7
  • Engineering PC
  • Ethernet Cables
  • Signal source for testing AIN0 and AIN1 on LabJack T7
Software
  • ctrlX OS v3.6
  • ctrlX WORKS v3.6
  • App Build Enviornment
  • Snapcraft
  • LabJack LJM 1.23.4 Linux x64 Package
  • Python 3.10
Network configuration
The ctrlX CORE and LabJack T7 must be reachable on the same network. For example -
  • ctrlX CORE - 192.168.1.1
  • LabJack T7 - 192.168.1.9
Step 1: Create the project structure
Fig. 1: Project structure
Step 2: Create the python script
Create the python script with the name 'main.py' and place it at the root location of the project folder.
This python script acts as a wrapper for the LJM library. It tries to establish the connection with LabJack T7, get the device info and reads both analog input channels every 500 milliseconds.
import time
from datetime import datetime
from labjack import ljm
DEVICE_IP = "192.168.1.9"
CHANNEL_NAMES = ["AIN0", "AIN1"]
READ_INTERVAL = 0.5
TEST_DURATION = 5
def main():
    handle = None
    try: # Open T7 over Ethernet using fixed IP
        print(f"Trying to connect to T7 at {DEVICE_IP} ...", flush=True)
        handle = ljm.open(ljm.constants.dtT7, ljm.constants.ctETHERNET, DEVICE_IP)
        print(f"Opened the handle", flush=True) # Get and print device info
        dev_type, conn_type, serial, ip_int, port, max_bytes = ljm.getHandleInfo(handle)
        print(" Connected to LabJack T7")
        print(f" Device Type : {dev_type}")
        print(f" Connection Type : {conn_type}")
        print(f" Serial Number : {serial}")
        print(f" IP Address : {ljm.numberToIP(ip_int)}")
        print(f" Port : {port}")
        print(f" Max Bytes / MB : {max_bytes}", flush=True)
        print("\nStarting simple reads (no stream, no file)...", flush=True)
        start_time = time.time() read_count = 0
        while time.time() - start_time < TEST_DURATION: # Read all requested channels in one call
            values = ljm.eReadNames(handle, len(CHANNEL_NAMES), CHANNEL_NAMES)
            read_count += 1
            ts = datetime.now().strftime("%H:%M:%S.%f")[:-3]
            line = f"[{ts}] Read #{read_count}: " + ", ".join( f"{name} = {val:.5f} V" for name, val in zip(CHANNEL_NAMES, values) )
            print(line)
            time.sleep(READ_INTERVAL)
        print(f"\nFinished test. Total reads: {read_count}", flush=True)
    except ljm.LJMError as e:
        print(" LJM Library Error:", e, flush=True)
    except Exception as e:
        print(" Unexpected Error:", e, flush=True)
    finally:
        if handle is not None:
            try:
                ljm.close(handle)
                print("Closed T7 handle.", flush=True)
            except Exception:
                print("Got an expection while closing handle", flush=True)
if __name__ == "__main__":
    main()
Step 3: Create snapcraft YAML file
Create the snapcraft.yaml and place it under the 'snap' folder
base: core22
version: '1.2'
summary: LabJack LJM driver for ctrlX CORE
description: LabJack LJM runtime (C library) packaged for ctrlX CORE. GUI tools are stripped.
grade: stable
confinement: strict
architectures:
  - build-on: [amd64, arm64]
    build-for: [amd64]
    build-for: [arm64]
parts:
  ljm:
    plugin: dump
    source: ./driver
    stage-packages:
      - libusb-1.0-0
    #   - libstdc++6
    #   - libc6
    override-build: |
      set -eux
      cd "$SNAPCRAFT_PART_SRC"
      chmod +x ./labjack_ljm_installer.run
      ### Install into the snap's filesystem (not the host)
      ./labjack_ljm_installer.run --accept --quiet --target "$SNAPCRAFT_PART_INSTALL/usr/local"
      ### Remove GUI app (Kipling) and host-specific bits we don't want on ctrlX.
      rm -rf "$SNAPCRAFT_PART_INSTALL/usr/local/labjack_kipling" || true
      rm -f  "$SNAPCRAFT_PART_INSTALL/usr/local/bin/labjack_kipling" || true
      rm -rf "$SNAPCRAFT_PART_INSTALL/opt" || true
      echo "Installed LabJack LJM into $SNAPCRAFT_PART_INSTALL/usr/local"
      ### Add a small test script for runtime verification
      mkdir -p "$SNAPCRAFT_PART_INSTALL/bin"
      cat > "$SNAPCRAFT_PART_INSTALL/bin/ljm-info" << 'EOF'
      #!/bin/sh
      export LD_LIBRARY_PATH="$SNAP/usr/local/ljm/lib:$SNAP/usr/local/lib:$LD_LIBRARY_PATH"
      echo "LJM libs:"
      ls -l "$SNAP/usr/local/ljm/lib"/libLabJackM.so* 2>/dev/null || echo "libLabJackM not found"
      echo "LJM driver installed inside snap at: $SNAP/usr/local"
      echo "Files:"
      ls -1 "$SNAP/usr/local" || true
      EOF
      chmod +x "$SNAPCRAFT_PART_INSTALL/bin/ljm-info"
  python-ljm:
    plugin: python
    source: .
    # Install LabJack's Python package (gives you `from labjack.ljm import ljm`)
    python-packages:
      - LabJackPython
    after: [ljm]
    override-build: |
      set -eux
      snapcraftctl build
      # Place your script inside the snap (adjust name/path as you like)
      mkdir -p "$SNAPCRAFT_PART_INSTALL/app"
      cp main.py "$SNAPCRAFT_PART_INSTALL/app/main.py"
      # Wrapper to run the script with correct env + library path
      cat > "$SNAPCRAFT_PART_INSTALL/bin/ljm-python-demo" << 'EOF'
      #!/bin/sh
      # Make sure LJM's shared library is visible to Python
      exec "$SNAP/usr/bin/python3" "$SNAP/app/main.py"
      EOF
      chmod +x "$SNAPCRAFT_PART_INSTALL/bin/ljm-python-demo"
apps:
  ljm-python-demo:
    command: bin/ljm-python-demo
    environment:
      LD_LIBRARY_PATH: "$SNAP/usr/local/ljm/lib:$SNAP/usr/local/lib:$LD_LIBRARY_PATH"
    plugs:
      - raw-usb
      - network
      - hardware-observe
plugs:
  raw-usb:
    interface: raw-usb
  hardware-observe:
    interface: hardware-observe
Step 4: Build the snap
From the project root, run:
snapcraft clean
snapcraft
After the successful packaging, the generated file should be similar to:
ctrlx-labjack-ljm_1.2.0_amd64.snap
Download the file to your computer
Step 5: Install the snap on ctrlX CORE
Open the ctrlX OS web interface and follow these steps:
  1. Open Settings
  2. Open Apps
  3. Select Install from file
  4. Select labjack-ljm_1.0.0_amd64.snap
  5. Complete the installation
Step 5: Check the logbook for the output
Fig. 2.: Output logs in Logbook from the python script stating successful connection to LabJack T7 device
Related links
