Codesys Webvisu - How to include reference variable string of frame object to translation list?
Hi all,
could you pls help me how to properly create Frame object so that one reference variable of "Label" would be included in translation list?
I have created my own Button and one of the reference variable is string to show the button Label. Because I want to change font color dynamicaly I implement this Caption inside myButton frame and use it in Text property.
The problem is that this variable is not included in translation list so I cannot use this method in case we would send the machine abroad.
After that I have tried to create frame with Frame Configuration tab I did not know before.
I create my properties and defined type of property which gives me possibility to use standard text which is included to translation list.
Problem is, as soon as I use this frame it have very limited properities in compare to standard object (e.g. input configuration and many more).
Do you have any hint how to somehow puzzle both ways together and create frame with all needed properties?
Thanks a lot.
P.
