cant generate CSR file for AWS IoT Core Client in Codesys
I am using the AWS IoT Core Client from the IIOT Library. I have the credentials and keys of the MQTT broker I want to connect to.
I need to create an CSR file in the PLC shell but the PLC shel is blank, see attachment. How can i create a CSR file without PLC shell?ย
I got credentials (Root Certificate and public & private key) from the AWS. I need codesys to allow these credentials.
How can install the credentials in Codesys?ย
Is this still an issue or can this topic be closed?
78.96KB
