09/18/2026
INSISO TECHNOLOGIES | APP | SENSE & VISION
InSiSo Technologies - InSiSo Visual Detector
InSiSo Visual Detector is a vision app for Bosch Rexroth ctrlX OS. It finds parts with a deep-learning model trained on your own images, or simply by colour. Every result goes to the ctrlX Data Layer, where PLC, Motion and HMI read it like any other process value.
Rule-based vision tools must be re-tuned for every new part or lighting change. Visual Detector learns what your parts look like from labelled examples instead. Images, models and results stay inside your network: there is no cloud in training or at runtime.
https://www.youtube.com/watch?v=ykeubIE8pPw
Key features
Your data stays in your plant
Models are trained in InSiSo Model Bench, on a Windows engineering PC you own. No images, labels or model files leave your network. That matters wherever part images may not be sent to a vendor cloud.
Models for your parts, not generic detection
The app runs a model trained for your parts, your camera and your lighting. A new part or a new line is a retraining job in InSiSo Model Bench. It needs no vendor involvement.
Native ctrlX OS integration
Visual Detector is installed, licensed and updated like any other ctrlX OS app. Results, status and diagnostics are ctrlX Data Layer nodes under insiso/visual-detector/. PLC, Motion and Node-RED read them without middleware.
From the PLC it takes three steps: wait for ready, write trigger, read the answer. Each picture's results arrive as arrays, with the picture number on every value. Every button in the app is also a Data Layer command.
Open camera choice
Connect GenICam / GigE Vision industrial cameras, USB / UVC cameras, or RTSP and HTTP streams. Each camera takes pictures in free run, on a software trigger from the PLC, or on its hardware trigger line. Several cameras can run on one device.
Positions in machine millimetres
The Machine Coordinate Transformation AddOn turns pixel positions into machine millimetres. A guided calibration with three or four points sets it up. The position goes straight to a robot or an axis.
More than object detection
  • Color Detection finds parts by colour, with no model to train.
  • Code Reading reads the Data Matrix inside each detected label.
  • 3D Dimensioning gives the length and width of each detected parcel in millimetres.
CPU, Hailo-8 or NVIDIA GPU
An .onnx model runs on the device's CPU, or on the NVIDIA GPU of a ctrlX IPC. On a ctrlX CORE with the Hailo-8 M.2 module, the model runs on the accelerator. Measured on a ctrlX CORE X7: a Model Bench parcel model takes 13.05 ms per frame on the Hailo-8, against 246 ms on the CPU.
Built for commissioning, then runs unattended
The web interface shows each detection on the live picture, with its class and confidence. Diagnostics answers "would a trigger work, and if not, why?" and shows the time each step takes. After a reboot the app reconnects its cameras, loads its model and detects. Nobody needs to press anything.
Closes the retraining loop
Pictures saved on the line go back to InSiSo Model Bench in one zip. Correct them, retrain and load the new model. A detection history, kept across power cycles, downloads as CSV.
Benefits
  • Detects application-specific parts and defects that rule-based vision cannot handle reliably
  • Full data sovereignty: training and inference both run on hardware you control
  • New parts are a retraining job, with no vendor dependency and no per-change engineering cost
  • Results native in the ctrlX Data Layer for PLC, Motion and HMI
  • Open camera choice: GenICam / GigE Vision, USB / UVC, RTSP and HTTP
  • Modular, perpetual licences: pay once, for the functions a cell uses
InSiSo Visual Detector brings trainable, application-specific object detection to ctrlX OS. The model, the data and the retraining loop stay under the machine builder's control.
Compatibility
  • ctrlX OS 4.x, tested on ctrlX OS 4.6
  • ctrlX CORE X3 (arm64)
  • ctrlX CORE X5, ctrlX CORE X7, ctrlX IPC and ctrlX CORE virtual (amd64)
  • Optional accelerators: Hailo-8 M.2 module on a ctrlX CORE; NVIDIA GPU on a ctrlX IPC with the NVIDIA extension
Latest version 4.7.21
  • First release for the ctrlX OS Store, October 2026
  • Camera Connector, Color Detection, Object Detection, Code Reading, 3D Dimensioning, Coordinate Mapping, Detection History and Diagnostics, on one Data Layer folder
  • Two snaps: arm64 for the ctrlX CORE X3; amd64 for the ctrlX CORE X5 and X7, the ctrlX IPC and ctrlX CORE virtual
  • Full release notes
  • A ctrlX OS device from the list above
  • A camera: GenICam / GigE Vision, USB / UVC, or an RTSP or HTTP stream
  • For Object Detection: a model exported from InSiSo Model Bench (.onnx, or a .zip with the .hef for the Hailo-8)
  • The Runtime licence, plus an AddOn for each function you use
Purchase requirements
Licensing model: perpetual. Every licence is a one-time purchase, and every licence can first be started as a trial.
The Runtime licence is required. Each AddOn unlocks one function. Detection History, Diagnostics and Help need no licence of their own.
Licence
What it unlocks
Purchase type
Runtime (required)
The app and the ctrlX Data Layer
One-time
1 Camera Connector AddOn
One connected camera. Buy one per camera; they add up
One-time
Color Detection
Parts found by colour
One-time
Object Detection AddOn
Detection with an InSiSo Model Bench model
One-time
One-time
Code Reading AddOn
The Data Matrix text inside detected labels
One-time
3D Dimensioning AddOn
Parcel length and width in millimetres
One-time
Vision Guidance Package
Runtime, Camera Connector, Object Detection and Machine Coordinate Transformation, as one licence
One-time
Example: a presence check with one camera and a trained model needs Runtime, 1 Camera Connector AddOn and Object Detection AddOn.
Additional notes
  • Order the licences in the ctrlX OS Store, then install them on the device under Settings ▸ Apps & Licenses.
  • Diagnostics ▸ Licence in the app shows every function as unlocked, included or locked.
Documentation
  • Online manual: installation, licensing, every page of the app, every Data Layer node and command
  • Test setup: a typical usage and test scenario
  • The manual as PDF is attached to this article.
InSiSo Technologies Customer Support
Attach the diagnostics zip (Diagnostics ▸ Download diagnostics (.zip)) to every support request.
Related links
Curious?
You can test many apps free of charge with a virtual control system provided by ctrlX WORKS. InSiSo Visual Detector runs on ctrlX CORE virtual, and every licence can be started as a trial. Just download ctrlX WORKS and follow this How-to.
InSiSo Technologies builds on-device computer vision for industrial automation. Model training and inference both run on hardware the customer already owns. That removes the cloud dependency most deep-learning vision products still carry.
InSiSo solutions are built on InSiSoNet, a proprietary on-device vision architecture. They are hardware-agnostic and deploy across a range of edge compute platforms. Machine builders and system integrators add trainable vision to existing lines without replacing their control architecture.
InSiSo Technologies is part of the SFAL K-Tech CoE, the Semiconductor Fabless Accelerator and Centre of Excellence for Semiconductors of the Government of Karnataka. It is a member of the NVIDIA Inception programme.
1) Note on data protection: The email is sent directly to the partner company! This company is responsible for the processing of the data contained. Please read their data protection information before sending this email! Bosch Rexroth is not responsible for the use of the partner company's support.
InSiSo Visual Detector 4.7.21 Manual.pdf
2.07MB
Categories
Sense & Vision
Platform
ctrlX OS
Vendor
Partner Apps
