Welcome to our innovative conveyor systems,
specially designed for material supply in supermarkets or directly at the workplace. Our systems offer you the ideal solution for the efficient supply of materials, wherever they are needed.
Our conveyor systems are designed for heavy loads and feature continuous rollers that facilitate the transport and supply of blisters or cartons. Our solutions are also available in an ESD-conductive version to protect sensitive electronic components.
Benefit from individual customization: Design your conveyor systems with tailored features and flexible dimensions to meet your specific needs. Our systems offer maximum flexibility and can be used both independently and in combination with other solutions.
Key Features & Benefits
Centralized or decentralized material supply – ideal for workplaces or supermarkets
Designed for high load capacities, suitable for robust production environments
Continuous rollers for smooth transfer of blisters, cartons, or containers
ESD-compliant versions for the protection of sensitive electronic components
Individually configurable in terms of dimensions, features, and color
Modular design – usable independently or combined with other systems
Expandable with accessories such as crossbeams or additional track elements
Available in – assembled or as a convenient kit
FIFO-compatible – for clean, traceable material flows according to the first-in, first-out principle
Kanban-compatible – for targeted and streamlined material supply
Get Inspiration
Our systems can be easily expanded with additional components such as crossbeams and conveyors. You can choose between a pre-assembled solution or a kit that you can assemble yourself.
For efficient material supply, our systems are ideal for systematic material flow in production (Kanban) and ensure effective material utilization through the FIFO (First In, First Out) principle. Invest in quality, flexibility, and efficiency – our conveyor systems will make your processes simpler and more effective!
Build your applications with Bosch Rexroth Products
Find further assembly technology applications by Bosch Rexroth:
