Palletizer for warehouse application
05/18/2026
Warehouse palletizers enhance operational efficiency by automating the process of stacking goods onto pallets. It systematically arranges products, such as cartons, bottles, or other packaging units, from a conveyor belt or another infeed source. This is done according to a predefined pattern to create a stable and transportable load unit, ready for shipping or storage.
This application is perfectly realized with the use of Rexroth profile rail systems and screw drives.
Key Features and Benefits
  • Increased efficiency and throughput
    Boost your overall efficiency by significantly reducing the time required for each task. It is designed for continuous operation, which eliminates costly downtime while ensuring consistent and reliable performance. This combination delivers a stable, predictable output
  • Lower labor costs
    By automating key processes, our solution allows you to operate with less staff, directly reducing labor costs. This automation also frees up your existing employees from repetitive tasks, enabling them to focus on more complex and value-adding activities.
  • Improved safety in the workplace
    Our solution enhances workplace safety by automating physically demanding or hazardous tasks. This actively reduces the risk of work-related illnesses and on-the-job accidents, creating a safer and more secure environment for all your employees.
  • Improved pallet quality and stability
    By creating consistently uniform and stable stacks, our solution significantly improves overall pallet quality and integrity. This precise palletizing process also optimizes the use of space, ensuring that every pallet is packed efficiently and securely for transport.
Get Inspiration
The integration of reliable components is crucial to ensure an optimal flow in the palletizing process. Rexroth's linear axis, linear guides, screw drives, ctrlX controllers and aluminum profiles work in harmony to improve precision, efficiency and flexibility and ensure that every palletizing process runs smoothly and effectively.
Find the mechanical solutions here
Find the automation solutions here
Application status
Configure
Order
Industry
Packaging Machines
Robotics
Warehouse Automation and Intralogistics
Technology
Linear Motion Technology
Electric Drives and Controls
