Precision and efficiency are critical to success in modern intralogistics. Our advanced components for autonomous mobile robots (AMRs) not only deliver exact positioning but also set new benchmarks for durability and cost-effectiveness. Discover how our systems can boost your performance while conserving resources.
Intelligent, flexible, self-propelled: autonomous mobile robots (AMR) are designed to revolutionize intralogistics. Important requirements for the electrified lifting systems are precise positioning, low complexity in engineering and implementation as well as a clean and low-maintenance solution. The electromechanical cylinder (EMC) is the heart of the lifting mechanism in AMRs and enables the load to be lifted and set down gently and positioned precisely.
Thanks to its extended lubrication intervals, the low-maintenance electromechanical actuator is an economical and resource-saving solution. Profiled rail systems and screw drives from the linear motion technology portfolio are also used in mobile robots. They form the basis for the fork cross adjustment of a mobile robot to pick up different types of pallets.
Key features and Benefits
Electromechanical cylinder - compact. finely adjustable. maintenance
Our innovative solutions, such as the electromechanical cylinder EMC, offer you a durable and low-maintenance alternative to conventional systems. These compact cylinders are not only finely adjustable and easy to maintain but also ensure high availability of your lifting systems.Linear guides and screw drives - precise. robust. durable. maintenance
Automatic fork cross adjustment for picking up different load carriers such as pallet types can be realized economically with profiled rail systems and screw drives from Bosch Rexroth. Whether as a standard or customized solution – we offer tailor-made solutions from a single source.
Get Inspiration
[boschtube src="https://bosch.mediaspace.de.kaltura.com/embed/secure/iframe/entryId/0_1qpflq0p/uiConfId/23459231/st/0"]
Optimizing lifting equipment in warehouses requires the use of high-quality components. Rexroth's linear guides, spindle drives, and controllers work together seamlessly to increase efficiency and flexibility, ensuring a smooth and effective process.
