Kanban Flow Racks for Lean Material Supply
05/18/2026
Kanban flow racks and supermarkets support lean production through efficient component provisioning based on the pull principle. The result: Reduced inventory, optimized cycle times, and minimized waste. Modular and configurable to your needs with flexible dimensions, conveyor belts, and castors, adapting perfectly to your requirements. For seamless material flow, centrally or directly at the workstation
Efficient material control is essential for lean production. Kanban flow racks implement pull and FIFO principles, reducing inventory and operating costs while ensuring continuous material flow directly at the workstation.
The Flow Rack XLean offers versatile use as a supermarket shelf or directly at the workplace for container precision. ESD-compliant available with conveyor belts and rollers in various colors. Individual customization tailored to your needs, modular use as standalone solution or in combination with existing systems.
The Rack EcoFlow is specially designed for heavy loads, featuring continuous rollers in an ESD-conductive version. Designed for high load capacities with individually configurable features and flexible dimensions. Modular design, expandable with accessories. Available as basic kit for self-assembly or pre-assembled solution.
The Flow Rack System LEAN features flexible flow racks with balls and guide rails. Colored rollers improve visibility, clearly visualizing material stock. Wide range of system components with rollers, guide rails, and ball-guided paths. Great design freedom with flexible dimensions and modular conveyor belts. Available as pre-assembled or self-assembly kit, easily expandable.
The EcoShape round tube system enables the rapid construction of flexible shelving units. Whether for supermarkets, workplace material supply, or logistics applications, EcoShape adapts to your requirements. The components are lightweight and allow for assembly without special tools.
All variants are FIFO-compatible, Kanban-compatible, and available in ESD-compliant versions.
Key Features & Benefits
  • Efficient material control: Implements pull and FiFo principles. Reduces inventory, minimizes scrap, and effectively lowers operating costs.
  • Continuous material flow: Ensures smooth supply at the workstation. Intuitive operation quickly detects replenishment needs and prevents waiting times.
  • Maximum flexibility & adaptation: Modular, individually configurable systems (steel profiles, plastic rollers). Flexible dimensions adapt to processes and factory space.
  • Versatile application possibilities: Can be used as a central supermarket or directly at the workplace. Available as a complete system or DIY kit, easily expandable.
  • Cost efficiency & quality: Optimizes material flows, reduces waste. A cost-effective and sustainable solution to improve production and increase competitiveness.
Get Inspiration
[gallery]
[youtube src=src="https://www.youtube.com/embed/7gqMFDYots8?si=2_ibwaRRLIJEZUGt"]
Application status
Configure
Industry
Assembly Systems
Battery
FMCG
General Automation
Healthcare & Medical
Machine Tools
Packaging Machines
Technology
Assembly Technology
