Material flow reimagined – flexible, efficient, and well-thought-out.
Our material supply solutions offer maximum versatility: Whether centrally located as a supermarket shelf or directly at the workstation – they support your production exactly where they are needed. Ideal for use in Kanban systems, they ensure a structured, continuous material flow and minimize search and setup times.
Key Features & Benefits
Versatile use – Can be used centrally as a supermarket shelf or directly at the workplace for container provision.
Efficient material supply – Ideal for systematic material flow in production (Kanban).
Versatile design – Conveyor belts and rollers in various colors.
Individual customization – Customized equipment and flexible dimensions.
Efficient material flows – Optimized by the FIFO principle.
Modular use – Can be used as a standalone solution or in combination.
Get Inspiration
Individually configurable with conveyor belts and rollers in various colors, our systems adapt perfectly to your requirements. Dimensions and equipment can be flexibly designed – for customized integration into your processes.
The FIFO (First In – First Out) principle organizes material flows efficiently and minimizes storage times. The modular design allows for use as a standalone solution or in combination with existing systems.
Build your applications with Bosch Rexroth Products
Find further assembly technology applications by Bosch Rexroth:
