Flow Rack System LEAN / Supermarket
09/11/2025
Benefit from high flexibility and a wide range of combinations: Choose from various conveying media such as rollers, roller elements, and guide rails to meet your specific requirements. Customize your conveyor systems with tailored features and flexible dimensions designed to fit your needs.
Use colored rollers for improved visibility, clearly visualizing material stock levels or good/bad parts. Our conveyor belts and rollers are available in a wide range of colors, allowing you to create an attractive work environment.
For special requirements, we also offer our systems in an ESD-conductive version to protect sensitive electronic components. You can choose between a pre-assembled solution or a kit for self-assembly.
Key Features & Benefits
  • Centralized or decentralized material supply – ideal for workplaces or supermarket areas
  • Wide range of system options with rollers, guide rails, and roller elements for customized applications
  • Tailor-made design – configurable dimensions, features, and assemblies
  • Colored components for easy identification of material status or storage areas
  • Great design freedom through a selection of different colored rollers and conveyor belts
  • ESD-compliant – also available in a conductive version for the protection of sensitive electronics
  • Assembly options – pre-assembled or as a self-assembly kit
  • Modularly expandable with combinable additional components such as crossbeams and other conveyor elements
  • FIFO-compatible – for structured material flows according to the first-in, first-out principle
  • Kanban-compatible – ideal for lean processes and efficient material supply
Get Inspiration
Easily expand your systems with additional components such as crossbeams and conveyors. Our solutions are ideal for systematic material flow in production (Kanban) and ensure efficient material utilization thanks to the FIFO (First In, First Out) principle. Take advantage of modular design: Our systems can be used independently or in combination with other solutions for maximum flexibility. Make your processes more efficient and effective with our innovative conveyors!
Build your applications with Bosch Rexroth Products
Find further assembly technology applications by Bosch Rexroth:
Application status
Configure
Industry
Assembly Systems
Battery
FMCG
General Automation
Healthcare & Medical
Machine Tools
Packaging Machines
Technology
Assembly Technology
